When I create a Field Statistics Chart to sum, average, etc... selected rows in an attribute table, the chart does not differentiate between the rows I have selected and the attribute table as a whole.
Here I have 6 of 12 records selected, but the "Dataset" and "Selections" columns are the same.
I've noticed this happens to layers that I have created using the "Make Layer from Selected Feature" function previously. That is to say, I've selected records I want to isolate from a larger dataset, made them into a separate layer by right-clicking the parent layer > Selection > Make Layer from Selected Feature, and then tried to filter a stats chart by a selection I've made in the resulting layer.
This doesn't happen if I instead export a selection to its own dataset, but exporting data I've temporarily chunked to their own shapefiles starts to pile up, and exporting to memory doesn't allow the layer to persist across sessions.
Is this a known bug? Something just happening to me? Not the developer-intended workflow?
I'm running ArcGIS Pro 2.7.3
