Export till CAD and hatch question
418
11-19-2023 10:57 PM
MikaelGöthammer
Hi!
I am using the Export to CAD GP-tool and the reserved CAD fields to ensure that presentation will be as I want on the CAD side.
I got symbols and line stiles to work as I want and also that objects are put on the correct layer.
But I don't get it to work for my polygons as I want. Polygons are exported as closed polyline but without pattern(hatch). I would like it to be a solid hatch with a color.
How do I do that?
Using ArcGIS Pro v.3.1
/Mike
David_McRitchie
Hey Mike,
This might be a silly question from me but are we seeing the output come out as a line feature rather than a polygon? If so then I would recommend using the Feature to Polygon tool in ArcGIS Pro to convert this to a feature which can have a hatch symbology applied.
Hope that helps,
David
Esri UK -Technical Support Analyst
MikaelGöthammer
I see that I was a bit unclear. I am NOT going from CAD to GIS.
I am going from GIS to CAD. I already have a polygon feature class in GIS that I try to export to CAD.
But I don't know how to use the CAD reserved fields to make it SOLID or with a Hatch at the CAD side.
Right know I only get a closed LWPolyline.
Hope this makes the question a bit clearer.
/Mike
JC-220
Let us know if you ever figured this out. I'm also trying to get filled polygons but having no luck.
David_McRitchie
Hey Mike,
Ah thank you for explaining, unfortunately, I don't have any experience with going GIS to CAD so this might be something to put a post up on any forms relating to your CAD software.
If the hatch is showing fine within ArcGIS then it might be a defect or limitation of the CAD software, so if possible I would test this on different platforms.
Sorry I couldn't help further on this,
David
