Export map series jpeg with suffix name only - 2.x vs 3.x
132
11-01-2024 12:21 PM
MatthewDriscoll
In earlier 2.x versions you could export your map series like 'folderlocation\.pdf' and it would export it with just the suffix name only.  In 3.x you cannot anymore?  It says something like 'folder location not available'.   I upgraded to 3.x so I could export the map series as jpegs.  The main reason I want the suffix name only is it makes it super simple to create a match table so I can create attachments with those jpegs.  Then later use the points in a story maps map tour.  Why the change?
