Elevation Feature
812
04-12-2024 03:01 PM
KIRNZAFAR
I want to have elevation feature in my map. For instance, when I zoom out it shows me just color-coded areas but when I zoom in, I can see the details. Can any one please help to add tis feature?
Thank you.
BillFox
MVP Frequent Contributor
Do you have some features with elevation values you want to look at in 3D?
Or are you just needing to look at some 3D maps for context?
KIRNZAFAR
I have electric network and I want to see loading of lines and voltages of buses.
JonDeRose
You mention elevation features; however, based on the description it sounds like you are looking for guidance on setting up display filters to display different features and/or labels at different scales.
Depending upon what you are looking to achieve, Containment Associations can also be used to control the level of detail shown in the map.
Does this align with what you are trying to achieve?
Jon
BillFox
how about this as a starting point?
https://learn.arcgis.com/en/projects/get-started-with-the-arcgis-utility-network/
"Jon DeRose is a product engineer on the geodatabase team and is passionate about using technology to bring order to chaotic systems."
