Dynamic Text based on map selection
293
01-17-2024 06:59 AM
ShaiBravo
Hi there,
Is it possible to create dynamic text in a layout based on my current map selection? I am creating a custom layout for an ArcGIS experience and would like the selection on that map to be populated in the layout.
Shai
AubriKinghorn
You can't create populate dynamic text based on the current map selection, but you can use a SQL query in value dynamic text to get the same result. Learn more here https://pro.arcgis.com/en/pro-app/3.1/help/layouts/add-dynamic-text.htm#GUID-890A21B3-C174-48EF-A33A...
Cheers,
Aubri
