Dark / Light 3D scene
300
3 weeks ago
TomášKlimeš
One of my 3D scenes is darker than the other one. Where could be the problem / difference in the settings? Both have enabled lighting. Just made a new Scene with exactly the same layers.Snímek obrazovky 2024-04-26 065516.png
Thanks.
Robert_LeClair
Esri Notable Contributor
Interesting.  Question for you - how was your first scene created? Did you use a scene layer package to create the scene?
TomášKlimeš
Thanks for responding! It was created from a 2D map and the brighter one by copying layers from the darker one. No, I did not use the scene layer package.
TomášKlimeš
It works! Thank you very much. There's a difference between creating New Local Scene and converting 2D Map to Local Scene when it comes to lighting.
Robert_LeClair
GREAT!  If you feel my response was the correct solution, you can click the "Accept as Solution" button to close out this thread.  Have a great weekend!
