Create network dataset
693
12-07-2021 09:44 AM
SilviaPanunzi
New Contributor II
Messages errors from ServiceArea analysis from Network Analysis:
"The network dataset has no edge elements. It may be unbuilt.
The operation was attempted on an empty geometry"
I tried to
1) build a network dataset but I didn't know how to do it starting from openstreet basemap so I used a roads shapefiles, containing only fields shape=polygon and length=meters and type=highway ecc..
2) do a service area analysis, importing facility locations and setting 5 kilometers as distance length
I got the message above.
Also, I tried to do a location-allocation analysis having as input: facilities locations, demand point (with population field in a column) and the network dataset above created, but of course it doesn't work this too.
DanPatterson
MVP Esteemed Contributor
Create Network Dataset (Network Analyst)—ArcGIS Pro | Documentation
You need polylines for the roads
... sort of retired...
SilviaPanunzi
New Contributor II
Sorry, spelling error are indeed polylines with other columns type (highway/service..) and Shape_Length.
SilviaPanunzi
New Contributor II
Sorry those are indeed polylines not polygons.
The error I get repeating the analysis is:
Solve
Parameters
Input Network Analysis Layer Service Area
Ignore Invalid Locations SKIP
Terminate on Solve Error TERMINATE
Simplification Tolerance
Network Analyst Layer Service Area
Solve Succeeded true
Overrides
Messages
Start Time: mercoledì 8 dicembre 2021 14:41:42
Location "92310" in "Facilities" is unlocated.
(same for many facilities id).......
WARNING 030247: One or more break values could not be reached by one or more facilities.
WARNING 030025: Partial solution generated.
So in the output I do not have any service area at all computed.
DanPatterson
030247: One or more break values could not be reached by one or more facilities.—ArcGIS Pro | Docume...
030025: Partial solution generated.—ArcGIS Pro | Documentation
for other error messages or warnings, just input the number in the help search ie 030247
