I suppose one way to do it would be to modify the existing query:
Details:
(1) Keep only the horizontal lines. Exclude the vertical lines.
where
startpoint_y = endpoint_y
Here's a sample horizontal line:
OBJECTID STARTPOINT_X STARTPOINT_Y ENDPOINT_X ENDPOINT_Y SHAPE
219 0 0 0 1 [SDO_GEOMETRY]
(2) Add an additional outer query where we generate 5 vertices (a polygon) from the existing 2 vertices (from the original horizontal line):
startpoint_x, --vertex 1 (original vertex from the horizontal line)
startpoint_y,
endpoint_x, --vertex 2 (original vertex from the horizontal line)
endpoint_y,
endpoint_x, --vertex 3
endpoint_y+1,
startpoint_x, --vertex 4
startpoint_y+1,
startpoint_x, --vertex 5 (same as vertex 1) https://gis.stackexchange.com/q/433083/62572
startpoint_y,
(3) Just like with the lines query, construct a polygon geometry by concatenating the coordinates together into WKT.
sdo_geometry('polygon(('||startpoint_x||' '||startpoint_y||', '||endpoint_x||' '||endpoint_y||', '||endpoint_x||' '||(endpoint_y+1)||', '||startpoint_x||' '||(startpoint_y+1)||', '||startpoint_x||' '||startpoint_y||'))',26917) as shape
(4) Now, the coordinates look like this (the vertex direction is counterclockwise; vertex 1 and 5 are both 0,0):
(5) This is what the full query looks like:
--create or replace view sdo_geom_grid_polygons_vw as (
select
objectid,
'polygon(('||startpoint_x||' '||startpoint_y||', '||endpoint_x||' '||endpoint_y||', '||endpoint_x||' '||(endpoint_y+1)||', '||startpoint_x||' '||(startpoint_y+1)||', '||startpoint_x||' '||startpoint_y||'))' as wkt,
from
with dimension as (
select 0 as point from dual
union all
select level
from dual
connect by level <= 10
), points as (
select
a.point as startpoint,
b.point as endpoint,
c.point as fixed
from dimension a
cross join dimension b
cross join dimension c
where b.point - a.point = 1
select
cast(rownum as number(38,0)) as objectid,
startpoint_x,
startpoint_y,
endpoint_x,
endpoint_y
from
select
startpoint as startpoint_x,
fixed as startpoint_y,
endpoint as endpoint_x,
fixed as endpoint_y
from points
union all
select
fixed as startpoint_x,
startpoint as startpoint_y,
fixed as endpoint_x,
endpoint as endpoint_y
from points
order by startpoint_x, startpoint_y, endpoint_x, endpoint_y
where
startpoint_y = endpoint_y --get horizontal lines only
