caculate field python invaild syntax
717
01-28-2023 04:42 PM
WilliamYu811
New Contributor II
Hi there,
I'm a newbie for python, trying to fill the <Null>  into 04 by using the "Caculate Field" function.
But it says I got some invaild syntax, not sure what's goion on after searching some tutorials on the internet.
I wan't to know how to make it work, thanks.
Sincerely,
Teng-Wei.
DanPatterson
MVP Esteemed Contributor
re  .... is the name of a python module change the function name, or perhaps use the following
... sort of retired...
DanPatterson
BarryNorthey
Occasional Contributor III
Dan's method above of selecting target records and then calculating on the selected records is a safe, easy and effective way to do this. Be sure to work on a copy of data when experimenting or alternately make sure that Undo is enabled so you can Discard edits when things go wrong.
Consider the option below:
Python is fussy about indentation and colons:
DanPatterson
!LOC! if !LOC! else "04"
Will do the same since <NULL> is effectively None
emulating a file in a table called LOC
LOC =['A', 'B', None, "D"]
[i if i else "04" for i in LOC]
Out[12]: ['A', 'B', '04', 'D']
JoshuaBixby
As pointed out by @BarryNorthey the specific syntax error you are getting is due to a lack of a colon after your function definition line.
Since you are new to Python, I will also point out that best practice according to https://peps.python.org/pep-0008/ :
Comparisons to singletons like None should always be done with is or is not, never the equality operators.
So, in this case your syntax should not be
if ( LC01 == None ) :   # which by the way you forgot another colon.
but should be
if ( LC01 is None ) :
As @DanPatterson has already pointed out, for a simple conditional check like this you can rely on Python's conditional expression, aka ternary operator, to handle it rather than defining a function in the code block.
"04" if !LC01! is None else !LC01!
