Is there a way to capture the version or full build number of ArcGIS Pro during install? Currently the build number does not help identify the actual version.
Example: ArcGIS Pro gets upgraded from 2.9.x to 2.9.6 but in Windows (Apps/Features) it still shows up as Build 2.9.32739, without a version. Makes it really hard to monitor what versions are installed across a large number of machines with things like SCCM.
Only work-around is by script and grabbing the version from
arcpy.GetInstallInfo()
rather than the Build Number. But why doesn't a combination of both get captured?
Registry shows:
Computer\HKEY_LOCAL_MACHINE\SOFTWARE\ESRI\ArcGISPro\Updates\2.9_0_6:
Name: ArcGIS Pro 2.9 Patch 6 (2.9.6)
