ArcGIS Pro 1.2, after update get warning message
3095
7
03-14-2016 03:19 AM
by Anonymous User
Not applicable
After upgrading from ArcGIS Pro 1.1.1 to 1.2, I get a popup message on startup of Pro:
"Not all requested extensions are available."
I can't find what extension of functionality this would be, any suggestions?
George_Thompson
Esri Frequent Contributor
Hi Lars,
How are you accessing your licenses for Pro 1.2? Internal Portal? ArcGIS Online?
--- George T.
by Anonymous User
Not applicable
Hi George,
I'm using internal Portal for licensing.
George_Thompson
Are you running Esri License Manager 10.4 also? This is a requirement for Pro 1.2 licensing.
ArcGIS Pro 1.2 system requirements—ArcGIS Pro | ArcGIS for Desktop
If licensing through Portal for ArcGIS, which is approximately a private version of ArcGIS Online, installation of Portal for ArcGIS 10.3 or later and ArcGIS License Manager 10.4 is required.
--- George T.
by Anonymous User
Not applicable
Hi George,
thanks for prompt reply.
I have Portal 1.3.1 but not Licence Manager 1.4 (yet). Except for the warning message, Pro seems to work fine.
Thanks.
Regards,
Lars
George_Thompson
Once you install and configure License Manager 10.4, it should take care of the messages.
--- George T.
TommyKöhn
Hi George!
I also have Portal 1.3.1 and made the upgrade to Esri License Manager 10.4 , but
I still got the warning "Not all requested extensions are available." Do you have some
more suggestions?
Best Regards
Kaj Waldenby
George_Thompson
I would recommend opening a support case and having them investigate the issue in more detail.
--- George T.
