Arcade Expression - Calculate Field vs Validation Rule
1243
02-03-2023 02:08 AM
TitusGian
I am trying to sieve out duplicate values within the column "ID" from the table "IDs" and am getting different results for using the same arcade expression with Calculate Field tool and Validation Rule. The expression gives the intended output for the Calculate Field tool but Validation Rule outputs Error 002717, at line 3, where it seems to suggest that it is unable to read the  ${id} variable. I have also tried the method of adding the string with the variable id to no avail.
var tbl = FeaturesetbyName($datastore, "IDs", ["ID"], false);
var id = $feature.ID
var query = `ID = ${id}`;
var countID = Count(Filter(tbl, query));
function isDup(value){
     if (value > 1){
         return false;
     } else {
         return true;
isDup(countID)
JohannesLindner
Do you have empty id values? In that case, your query would be "ID = ", which is an invalid query.
if(id == null) { return false }  // feature is invalid if no id
var query = "ID = @ID";  // try using this notation instead
return countID == 1  // valid if exactly 1 feature has this ID, else invalid
Have a great day!
Johannes
JohannesLindner
Have a great day!
Johannes
TitusGian
There weren't any empty records. But the query fix you suggested worked for line 3 of the original code.
Thank you so much, @JohannesLindner !
