Adding NetCDF files as multivariate multidimensional raster in ArcGIS Pro Model Builder
468
07-21-2022 11:51 AM
NDetenbeck
There are functions in ArcGIS Pro to read in NetCDF files and create a single value raster but in order to create a multi-dimensional raster one needs to use Add Data and select multidimensional raster as the desired output. This option also allows one to interpolate values using nearest neighbor sampling which is necessary if the provided coordinate values are not quite equally spaced (as in our case). We wish to incorporate this step into a ModelBuilder process because we have hundreds of NetCDF files to process.
Robert_LeClair
Esri Notable Contributor
I wonder if you can use the Make NetCDF Raster Layer (Multidimensional) GP tool along with an Iterate Files ModelBuilder tool.  Would that work for your purposes?
NDetenbeck
No, that only allows you to select a single variable.  I'm working with multiple bands.
