Please allow to remove file extent for LAS on ArcGIS Pro.
Loaded LAS data on ArcMap, ArcScene, and ArcGIS Pro. On ArcGIS Pro, I couldn't remove file extent for LAS.
I could make it transparent, but the boundaries were still there.
I want to remove the file extent(red boundaries) and export the scene with basemap on a full extent.
I want to display points at 1200m map frame scale to see all the data on one sight, but the file extent doesn't disappear).
The extent is still there when he save the Scene to pdf.
ArcMap and ArcScene can disable the file extent by unchecking "Always display LAS file extents" option.
But I have to use ArcGIS Pro because ArcScene doesn't support basemaps.
Thank you.
Best,
Joora
