Expand docked attribute table width in ArcGIS Pro
1821
09-13-2017 10:17 AM
Status: Open
deleted-user-sYHsW3p_gN5o
Occasional Contributor II
In Pro, if I have the Contents pane docked on the left and any other pane docked on the right, my attribute table sits at the bottom in between the two. Why can't I choose to have it cover the entire bottom of the screen? I only need the contents pane to be so tall, so I'd like to be able to see more attribute columns instead.
attribute_table  docking‌ panes‌ attributes pane‌ attributetable‌ arcgispro‌ arcgis pro tables‌
3 Comments
KoryKramer
The idea is valid, but I just wanted to share that if you hide panes on the side, you'll get the entire screen width for your attribute table:
Thanks for the response Kory. That is useful in some circumstances, but often i do need to also see the Table of Contents and/or the Geoprocessing/Catalog/other pane.
KoryKramer
In response to https://community.esri.com/ideas/14052-arcgis-pro-remember-attribute-table-location, in ArcGIS Pro 2.5 it will be possible to approximate the request here with the exception that the table won't be docked.
For example,
