When adding a CAD .dwg to Pro the CAD annotation color and location don't match how it looks in AutoCAD. This seems to be an area that needs improvement. Does anyone else have this problem?
I found an old BUG-000084139 : Stacked annotation feature classes are displayed incorrectly when exported to CAD and viewed in a CAD Viewer. The same annotations appear black in color when imported from CAD to geodatabase in ArcMap.
It seems like it is not within the scope of the CAD to Geodatabase tool to import the color symbology of CAD text entities. There are several defects regarding annotations.
Is this issue encountered with a different .DWG file as well? Have we imported the .DWG file into a file geodatabase or an enterprise geodatabase? Are we noticing any discrepancy in the areas of the features if compared to the data seen in AutoCAD and ArcGIS Pro?
This is a native CAD .dwg. I have not imported CAD to geodatabase. I don't need to or want to - this is for viewing purposes only. It would save me time and headaches to be able to see this in Pro how it was intended instead of having to visually compare ArcGIS Pro on one screen and DWG TrueView of the .dwg on the other screen.
This happens frequently with all different .dwgs that I receive from other people. And it's been happening for years. I can't be the only one - I might have to post to the AEC group to ask also.
The lines and polygons (areas and locations) seem to read perfectly fine within ArcGIS Pro. I use these survey grade .dwgs to create GIS polygons so thank goodness that's working.
But since you are finding defects and bugs related to this idea it would seem the software is not capable of viewing CAD .dwg annotation correctly in ArcGIS Pro, yet anyway. The position, size of text, and color of text are not matched.
It's not annotation at all - it's a point that's labeled. Don't call it "Annotation and Annotation Group" in ArcGIS Pro, please. How very misleading. This will never match what the CAD .dwg shows. So this idea should be clarified: Have ArcGIS Pro treat CAD annotation as annotation and read all of the properties of the annotation.
I ran the CAD to Geodatabase tool - far worse results than reading the native cad file:
What happened to the "Import CAD Annotation Tool" that existed in ArcMap?
Thanks for posting this idea, and for the clarification given in 04-05-2023: "Have ArcGIS Pro treat CAD annotation as annotation and read all of the properties of the annotation."
In ArcGIS Pro 3.2, when reading in CAD datasets, default feature classes now include Point, Polyline, Polygon, Annotation (newly added), and Multipatch.
catch(e){
if (newSub.getAttribute("slang").toLowerCase() != code_l.toLowerCase()) {
if (trLabelsHtml != "") {
var labelSname = "";
if(labelEle[i].querySelector("ul li:nth-child(1)").getAttribute("aria-hidden")){
labelSname = labelEle[i].querySelector("ul li:nth-child(1)").outerHTML;
labelEle[i].innerHTML = "";
labelEle[i].innerHTML = labelSname + trLabelsHtml;
catch(e){
/* V 2.0:3 = Store not translated reply id */
if(lingoRSXML.snapshotLength == 0){
if($scope.falseReplyID == "") {
$scope.falseReplyID = value;
/* Get translated Body of Replies/Comments */
var lingoRBXML = doc.evaluate(lingoRBExp, doc, null, XPathResult.UNORDERED_NODE_SNAPSHOT_TYPE, null);
for(var i=0;i 0) {
var attachDiv = rootElement.querySelector('div.lia-quilt-row-main').querySelector('div.custom-attachments');
if (attachDiv) {
attachDiv = attachDiv.outerHTML;
else if(rootElement.querySelector('div.lia-quilt-row-main').querySelectorAll('#attachments').length > 0){
if ("IdeaPage" == "BlogArticlePage") {
attachDiv = rootElement.querySelector('div.lia-quilt-row-main .lia-message-body-content').querySelector('#attachments');
if (attachDiv) {
else{
attachDiv = "";
}else{
attachDiv = rootElement.querySelector('div.lia-quilt-row-main').querySelector('#attachments').outerHTML;
else {
attachDiv = "";
/* Feedback Div */
var feedbackDiv = "";
var feedbackDivs = rootElement.querySelector('div.lia-quilt-row-main').querySelectorAll('div.lia-panel-feedback-banner-safe');
if (feedbackDivs.length > 0) {
for (var k = 0; k < feedbackDivs.length; k++) {
feedbackDiv = feedbackDiv + feedbackDivs[k].outerHTML;
else {
var attachDiv = rootElement.querySelector('div.lia-message-body-content').querySelector('div.Attachments.preview-attachments');
if (attachDiv) {
} else {
attachDiv = "";
/* Everyone tags links */
if (document.querySelectorAll("div.TagList").length > 0){
var everyoneTagslink = document.querySelector('div.lia-quilt-row-main').querySelector(".MessageTagsTaplet .TagList");
if ((everyoneTagslink != null)||(everyoneTagslink != undefined)){
everyoneTagslink = everyoneTagslink.outerHTML;
else{
everyoneTagslink = "";
/* Feedback Div */
var feedbackDivs = rootElement.querySelector('div.lia-message-body-content').querySelectorAll('div.lia-panel-feedback-banner-safe');
for (var m = 0; m < feedbackDivs.length; m++) {
feedbackDiv = feedbackDiv + feedbackDivs[m].outerHTML;
} catch (e) {
if (body_L == "") {
/* V 2.0:7 Replacing translated video data with source video data */
var newBodyVideoData = newBody.querySelectorAll('div[class*="video-embed"]');
angular.forEach($scope.videoData[value], function (sourceVideoElement, index) {
if (index <= (newBodyVideoData.length - 1)) {
newBodyVideoData[index].outerHTML = sourceVideoElement.outerHTML
/* V 2.0:7 = Replacing translated image data with source data */
var newBodyImageData = newBody.querySelectorAll('[class*="lia-image"]');
angular.forEach($scope.imageData[value], function (sourceImgElement, index) {
if (index <= (newBodyImageData.length - 1)) {
newBodyImageData[index].outerHTML = sourceImgElement.outerHTML;
/* V 2.0:7 = Replacing translated pre tag data with source data */
var newBodyPreTagData = newBody.querySelectorAll('pre');
angular.forEach($scope.preTagData[value], function (sourcePreTagElement, index) {
if (index <= (newBodyPreTagData.length - 1)) {
newBodyPreTagData[index].outerHTML = sourcePreTagElement.outerHTML;
var copyBodySubject = false;
if (body_L == "") {
copyBodySubject = true;
body_L = newBody.innerHTML;
/* This code is written as part of video fix by iTalent */
/* try{
var iframeHTMLText = body_L;
var searchIframeText = "<IFRAME";
var foundiFrameTag;
if (iframeHTMLText.indexOf(searchIframeText) > -1) {
foundiFrameTag = decodeHTMLEntities(iframeHTMLText);
foundiFrameTag = foundiFrameTag.split('src="')[1];
body_L = foundiFrameTag;
catch(e){
/* This code is placed to remove the extra meta tag adding in the UI*/
try{
body_L = body_L.replace('<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />','');
catch(e){
/** We should not replace the source content if user profile language and selected target language matches with source language **/
if(showTrContent) {
var compiled = false;
rootElement.querySelectorAll('div.lia-message-body-content')[0].innerHTML = null
if("IdeaPage"=="IdeaPage"){
// var customAttachDiv = '';
rootElement.querySelectorAll('div.lia-message-body-content')[0].innerHTML = body_L + feedbackDiv ;
$compile(rootElement.querySelectorAll('div.lia-message-body-content')[0])($scope);
compiled = true;
/* Attach atttach div */
// document.querySelector("div.translation-attachments-"+value).innerHTML = attachDiv;
rootElement.querySelectorAll('div.lia-message-body-content')[0].insertAdjacentHTML('afterend',attachDiv);
if(rootElement.querySelectorAll('div.lia-quilt-idea-message .lia-message-body .lia-attachments-message').length > 1){
rootElement.querySelectorAll('div.lia-quilt-idea-message .lia-message-body .lia-attachments-message')[1].remove();
} else {
if("IdeaPage"=="TkbArticlePage"){
}else{
rootElement.querySelectorAll('div.lia-message-body-content')[0].innerHTML = body_L + feedbackDiv + attachDiv;
compiled = true;
/* Destroy and recreate OOyala player videos to restore the videos in target languages which is written by iTalent as part of iTrack LILICON-79 */ /* Destroy and recreate OOyala player videos */
try{
// $scope.videoData[value][0].querySelector("div").getAttribute("id");
for(var vidIndex=0; vidIndex<$scope.videoData[value].length; vidIndex++){
if( $scope.videoData[value][vidIndex].querySelector("div") != null){
var containerId = LITHIUM.OOYALA.players[$scope.videoData[value][vidIndex].querySelector("div").getAttribute("id")].containerId;
videoId = LITHIUM.OOYALA.players[$scope.videoData[value][vidIndex].querySelector("div").getAttribute("id")].videoId;
/** Get the Video object */
vid = OO.Player.create(containerId,videoId);
/** Destroy the video **/
vid.destroy();
/** recreate in the same position */
var vid = OO.Player.create(containerId,videoId);
catch(e){
try{
for(var vidIndex=0; vidIndex<($scope.videoData[value].length); vidIndex++){
if($scope.videoData[value][vidIndex].querySelector('video-js') != null){
var data_id = $scope.videoData[value][vidIndex].querySelector('video-js').getAttribute('data-video-id');
var data_account = $scope.videoData[value][vidIndex].querySelector('video-js').getAttribute('data-account');
var data_palyer = $scope.videoData[value][vidIndex].querySelector('video-js').getAttribute('data-player');
var div = document.createElement('div');
div.id = "brightcove";
div.class = "brightcove-player";
div.innerHTML =
'(view in my videos)'
var data = div.getElementsByClassName("video-js");
var script = document.createElement('script');
script.src = "https://players.brightcove.net/" + data_account + "/" + data_palyer + "_default/index.min.js";
for(var i=0;i< data.length;i++){
videodata.push(data[i]);
for(var i=0;i< videodata.length;i++){
document.getElementsByClassName('lia-vid-container')[i].innerHTML = videodata[i].outerHTML;
document.body.appendChild(script);
catch(e){
if(!compiled){
/* Re compile html */
if (code_l.toLowerCase() != newBody.getAttribute("slang").toLowerCase()) {
/* Adding Translation flag */
var tr_obj = $filter('filter')($scope.sourceLangList, function (obj_l) {
return obj_l.code.toLowerCase() === newBody.getAttribute("slang").toLowerCase()
if (tr_obj.length > 0) {
tr_text = "Esri may utilize third parties to translate your data and/or imagery to facilitate communication across different languages.".replace(/lilicon-trans-text/g, tr_obj[0].title);
try {
if ($scope.wootMessages[$rootScope.profLang] != undefined) {
tr_text = $scope.wootMessages[$rootScope.profLang].replace(/lilicon-trans-text/g, tr_obj[0].title);
} catch (e) {
} else {
//tr_text = "This message was translated for your convenience!";
tr_text = "Esri may utilize third parties to translate your data and/or imagery to facilitate communication across different languages.";
try {
if (!document.getElementById("tr-msz-" + value)) {
var tr_para = document.createElement("P");
tr_para.setAttribute("id", "tr-msz-" + value);
tr_para.setAttribute("class", "tr-msz");
tr_para.style.textAlign = 'justify';
var tr_fTag = document.createElement("IMG");
tr_fTag.setAttribute("class", "tFlag");
tr_fTag.setAttribute("src", "/html/assets/langTrFlag.PNG");
tr_fTag.style.marginRight = "5px";
tr_fTag.style.height = "14px";
tr_para.appendChild(tr_fTag);
var tr_textNode = document.createTextNode(tr_text);
tr_para.appendChild(tr_textNode);
/* Woot message only for multi source */
if(rootElement.querySelector(".lia-quilt-forum-message")){
rootElement.querySelector(".lia-quilt-forum-message").appendChild(tr_para);
} else if(rootElement.querySelector(".lia-message-view-blog-topic-message")) {
rootElement.querySelector(".lia-message-view-blog-topic-message").appendChild(tr_para);
} else if(rootElement.querySelector(".lia-quilt-blog-reply-message")){
rootElement.querySelector(".lia-quilt-blog-reply-message").appendChild(tr_para);
} else if(rootElement.querySelector(".lia-quilt-tkb-message")){
rootElement.querySelector(".lia-quilt-tkb-message").appendChild(tr_para);
} else if(rootElement.querySelector(".lia-quilt-tkb-reply-message")){
rootElement.querySelector(".lia-quilt-tkb-reply-message").insertBefore(tr_para,rootElement.querySelector(".lia-quilt-row.lia-quilt-row-footer"));
} else if(rootElement.querySelector(".lia-quilt-idea-message")){
rootElement.querySelector(".lia-quilt-idea-message").appendChild(tr_para);
} else if(rootElement.querySelector('.lia-quilt-occasion-message')){
rootElement.querySelector('.lia-quilt-occasion-message').appendChild(tr_para);
else {
if (rootElement.querySelectorAll('div.lia-quilt-row-footer').length > 0) {
rootElement.querySelectorAll('div.lia-quilt-row-footer')[0].appendChild(tr_para);
} else {
rootElement.querySelectorAll('div.lia-quilt-column-message-footer')[0].appendChild(tr_para);
} catch (e) {
} else {
/* Do not display button for same language */
// syncList.remove(value);
var index = $scope.syncList.indexOf(value);
if (index > -1) {
$scope.syncList.splice(index, 1);
/* V 1.1:2 = Reply Sync button for multi source translation */
} catch(e){
console.log(e);
if((rContent != undefined) && (rContent != "")) {
drawCanvas(decodeURIComponent(rContent));
/** Update variable with selected language code **/
$scope.previousSelCode = code_l;
* @function manageTranslation
* @description Managess the translation of given language for the thread
* @param {string} langCode - Language Code
* @param {string} tid - Thread ID
$scope.manageTranslation = function (langCode, tid) {
//debugger;
$scope.showTrText = false;
/* V 2.0:5 = actualStatus variable introduced to indicate detailed connector status on UI. This variable holds the actual translation percentage */
$scope.transPercent = "";
$scope.actualStatus = "";
if (tid != "") {
var bulkTranslation = lithiumPlugin.bulkTranslation(langCode, tid);
bulkTranslation.then(function (trContent) {
if(trContent.body != "") {
$scope.showPreview(trContent.body, $scope.mszList, langCode);
if(langCode != "en-US") {
$scope.showTrText = true;
if((trContent.status != "NA") && trContent.status != null) {
// $scope.transPercent = String(trContent.status);
$scope.actualStatus = String(trContent.status);
} else {
// $rootScope.errorMsg = "Translation is in progress. Please check again a few minutes."
$rootScope.errorMsg = "Translation is in progress. Please retry in a few minutes."
$scope.workbench = trContent.wb;
/* V 2.0:4 = Trigger uncalled or delayed callbacks (documnet uploaded/translation completed from lithium).*/
if(trContent.callback == 'true') {
var trCompletCallback = lithiumPlugin.trCompletCallback(langCode, trContent.docID);
trCompletCallback.then(function (callback){
// $rootScope.errorMsg = "Downloading Translated content in " + langCode + " now. Please check again in a few minutes."
$rootScope.errorMsg = "Uploading content to translate. Please check again in a few minutes."
} else if (trContent.callback == 'upload') {
var trCompletUpload = lithiumPlugin.trCompletUpload(langCode, trContent.docID);
trCompletUpload.then(function (callback) {
//$rootScope.errorMsg = "Uploading content to translate. Please check again in a few minutes."
} else if ("many" == "one") {
$scope.updateOOS();
} else if("SmartConx" == "SmartConx"){
if ("many" == "many"){
$scope.updateOOS();
}else if ((trContent.status != null) && trContent.status.includes("100")) {
/* If everything fine then only check Out of Sync status */
$scope.updateOOS();
} else {
/* If translation perccent is less than 100 then show the percentage on UI */
$scope.transPercent = $scope.actualStatus;
* @function selectThisLang
* @description Called on select dropdown.
* @param {string} lang - Language code
$scope.selectThisLang = function (lang, anonymousFlag) {
/* 1.4:3 Update Analytics on language selection */
try {
lingoThreadLangSelected(lang, '1275454');
} catch (e) {
/** Display Translated content **/
var getTranslation = lithiumPlugin.getTranslation(lang, "1275454");
getTranslation.then(function (trContent) {
if (trContent.body != "") {
$scope.showPreview(trContent.body, $scope.mszList, lang);
} else {
//$rootScope.errorMsg = "Translation is in progress. Please check again in a few minutes."
var decodeEntities = (function() {
// this prevents any overhead from creating the object each time
var element = document.createElement('div');
function decodeHTMLEntities (str) {
if(str && typeof str === 'string') {
// strip script/html tags
str = str.replace(/
