The "Change Version" tool currently allows you to change a version for a single layer. Normally when we want to change a version we do so for ALL layers in the active maps versioned datasource. The "change version" method on the Version ribbon lets us do this interactively.
I was quite happy to find the "Change Version" tool but when I started to use it, found that it only worked for a single layer or the fabric. Unfortunately, having multiple layers with different versions can cause problems. Also looping through ALL the layers in the active map can also be problematic.
I would like this tool to function the same way the ChangeVersion method works on the Versioning ribbon.
