Trying to copy parcel fabric from desktop to SDE getting failed paste error
217
03-25-2024 10:38 AM
N8B6688
New Contributor II
Had to remove my parcel fabric from the SDE and when I try to add it back in I keep getting the following error. I am able to paste every other type of data into the sde except a parcel fabric. Even creating a new blank parcel fabric I cannot paste it.
Parcel Fabric version 5.0
Acpro 3.2.1
Failed to paste.
FDO error: -2147217129.
jcarlson
MVP Esteemed Contributor
There is a geoprocessing tool specifically for copying a parcel fabric.
https://pro.arcgis.com/en/pro-app/latest/tool-reference/parcel/copy-parcels.htm
- Josh Carlson
Kendall County GIS
N8B6688
New Contributor II
Thank you, I also get an error 999999 "something unexpected" using that tool resulting in a failed to execute. The only relevant thing I am given is the "the operation was attempted on an empty geometry".
FrankConkling
New Contributor III
It sounds like you are receiving that error because of geometry issues with the features in the Parcel Fabric.  This often happens when one stores the data in a file geodatabase and attempts to move the data to SDE. SDE contains stricter geometric rule enforcement for the data when copying it into an Enterprise geodatabase.  I suggest you run Repair Geometry against all feature classes in the feature dataset containing the Parcel Fabric and then attempt to copy the feature dataset again.
Good Luck,
Frank Conkling - Panda Consulting
PaulWilkinson
New Contributor II
Try changing the SDE connection to Branch. I had a similar issue and it worked.
