How do I label my traverses with the bearing and distance in real time?
298
03-28-2024 12:11 PM
VogtBoat
I would like to learn how to label my traverse tool lines with bearing and distance measures while actively creating the traverse - as seen in the YouTube below. When I turn on the labels for my line layer, all that is available it a length field, and it is not ground-to-grid corrected.
Do I need to be creating my traverses in my connection lines feature class in my Parcel Fabric? Is this because they are COGO enabled?
See below example
https://www.youtube.com/watch?v=l1DShUY43zc
MatthewBeal
Are your construction lines part of the parcel fabric? Do you have the Number formats set up in the attribute table and labels cut on for that feature class? My lines are labeled as I sketch them in 3.2.2
MatthewBeal
VogtBoat
Yep! That did the trick! Thank you @MatthewBeal
