When you are in a traverse, the line type is defined by your feature templates, which are available as a dropdown in the traverse window.
In order to set a default attribute, open up the properties of a given template, then navigate to the attributes tab of the template properties window.
You can also create a new template, and it will appear in the Traverse as well.
- Josh Carlson
Kendall County GIS
