"Survey Point" label from Survey 123
788
03-28-2023 12:56 PM
DylanCummings28
How do I change the data labels on the hosted feature layer created by my Survey 123 form? When I add the layer to my map the data label next to the point symbol just says "Survey Point".....but I can't seem to figure out how to change it.
Katie_Clark
This documentation may help...
https://doc.arcgis.com/en/arcgis-online/create-maps/configure-labels-mv.htm
Best,
Katie
If this answer helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
