How to change the editing permissions on arc online
1336
06-18-2021 12:02 PM
LauraRaposo
Hello ESRI Community,
I am working on arc online at the moment and I want to update an attribute table, although I don't think the layer is editable at the moment. How do I change the editing permissions so I am able to update some of the info held it in. This map is being used in a dashboard as well, so I didn't want to export it as a new editable feature (so I wouldn't have to re-do some of the associated graphs that are in the dashboard. Any help would be greatly appreciated)
Best,
Laura
JayantaPoddar
Re you working on hosted feature layers?
In Item Details > Settings, you may enable editing. Please check the steps in Manage Editor Settings - Hosted Feature Layers   (do not enable public data collection). It can be executed by the owner of the item.
Enable the minimum editing capabilities required.
Think Location
JayantaPoddar
Think Location
LauraRaposo
Hi Jayanta
Thankyou, that worked perfectly 🙂
Best,
Laura
JayantaPoddar
Great!
Could you accept the post as a solution? This would highlight the post as "Solved", and help other users looking for a similar solution as well.
Think Location
