How to add Mapbox Vector Tile service (.pbf TileLayer) to map viewer
1716
6
11-07-2022 01:30 AM
CBREEMEA
New Contributor II
Hello,
I am trying to add to ArcGIS Online map viewer the OpenInfraMap tile layer (OSM power networks of all over the world) but I'm not sure if this Mapbox Vector Tiles format service is supported as is.
In the "About" section it is possible to find the link to the TileJSON file with its definitions and the tile layer URL:
https://openinframap.org/tiles/{z}/{x}/{y}.pbf
I'm able to add it to the web map but don't get any tiles.
Any ideas? Is it really supported in map viewer?
Thanks in advance,
António
David_Brooks
MVP Regular Contributor
@CBREEMEA im having the exact same issue. Have reached out to the developer
David
..Maps with no limits..
CBREEMEA
New Contributor II
Thanks, @David_Brooks!
Let's see what will be the trick to solve the riddle. 😉
Regards,
António
KevinMilton2
Were you ever able to figure this out?
ClaireCG
New Contributor II
Good morning @CBREEMEA @David_Brooks
Have you heard back from Russ Garrett?
I am encountering the same issues.
Many thanks for your feedbacks!
ThomasPrime
I am also unable to add a vector tile layer to ArcMap Online it is a third party one in the same format as the Openinframap above so would appreciate know if it is possible.
NAJBA
Any luck with the process?  I'm trying to import a TileJSON file into ArcGIS Pro.  Any help is appreciated!  Thanks.
