How to add domain to ArcGIS Solution
1024
06-24-2021 08:48 AM
irector_tlg
I recently deployed the Sewer Data Management for ArcGIS Online Solution. After adding my data, I wanted to add a new field and domain to one of the existing layers but, so far,  I’ve only been able to figure out how to add the field. There doesn’t seem to be a place to add a domain in AGOL and when I try and add the domain in ArcPro, it says the domains are read only and cannot be added to.
I’m sure I must be missing something because I’m just trying to create a new domain which should be pretty simple.
Waffle_House
Occasional Contributor II
The place to access the domains in AGOL is by clicking on the field in the Data tab and accessing its "List" as described here: https://doc.arcgis.com/en/arcgis-online/manage-data/define-attribute-lists-and-ranges.htm#GUID-6E9A9...
Send screenshots of what you see for that field.
irector_tlg
As you can see, there is no place to add a new list.
Waffle_House
Was it published by someone else and you do not have edit permissions? What are the sharing permissions for the feature layer?
GelisaJoseph
The Creator field you are showing is a for editor tracking so a list cannot be added to that field. Can you create a list for a field such as the Notes field?
irector_tlg
The layer was published by me and shared with me.
