How can I add a MAP SERVICE sub-layer to Web Viewer?
453
02-06-2024 07:32 AM
WilsonLee
Hello,
I have a Map Service (published from our on-prem ArcGIS Server and host the layer in AGOL), How can I add a MAP SERVICE sub-layer to Web Viewer?
(In the Web Map Classic Version, after i added a Map Service, i can get the URL of the sub-layer and add the sub-layer URL directly, but it doesn't work for the New Map Viewer)
thanks,
W
Tags (1)
KenBuja
MVP Esteemed Contributor
You can add the URL directly by clicking Add and selection Add layer from URL
This brings up the Add layer dialog, which accepts the sub-layer URL
RhettZufelt
MVP Notable Contributor
Select the sub-layer you want.  Upper right, click Properties, expand "Information", then click on the layer name.  This will take you to the REST endpoint of the sub-layer.
R_
WilsonLee
thanks all...yes, i have the rest URL , then "add layer from URL", but it doesn't work..(The classic version is fine) , any idea?
RhettZufelt
Can you share the REST url?  I am having no issues in new map viewer (at least with this :).
R_
WilsonLee
Thanks! Unfortunately, the service is locked and the content is confidential.
I will contact Esri Tech Support regarding the error message 🙏
