Hosted Feature Layer from Survey 123 Form
1906
03-28-2023 11:38 AM
DylanCummings28
I created a form using Survey 123. The results from that form are then stored in AGOL as a hosted feature layer. When initially creating the form I had one element that was a multiple choice selection where you could pick from 3 different options. After some time I decided to get rid of the third option so I edited the form and republished it. I also went into the hosted feature layer and edited the values to get rid of those values. After doing all of that, all of the maps that are using my hosted feature layer are still recognizing that 3rd option as a valid field paramater. For example, if I display the layer by "Facility Type" there are only 2 values, but the legend still has a placeholder for the 3rd value that I deleted, or if I add a user input filter for "Facility Type" it still has that 3rd value I deleted as a placeholder. How do I make AGOL quit recognizing the field value that I deleted from the form and from the attributes table???
Katie_Clark
In ArcGIS Online, locate the feature layer associated with the survey and open the item details page. Click on Data > Fields and then click on the field name that has the choice list that you want to edit. Scroll down and click on Edit for the list.
Best,
Katie
If this answer helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
Katie_Clark
Have you also deleted the value from the choice list that can be viewed through the Item Details page of the feature layer?
Best,
Katie
DylanCummings28
Not sure, how exactly do you do that?
Katie_Clark
Best,
Katie
DylanCummings28
HA! YES! Thank you 😁
