Hi @JohnEvans6 , it’s me again, sorry…..
I keep getting errors and I have a tough time understanding the syntax fully. I’m not sure what I have wrong. I've tried a bunch of different iterations, but below is the current iteration that I have. The portions marked with yellow I’m not fully following what they represent and where those pieces are being pulled from.
What does f.XYjoin represent on line 8?
What do lines 10 & 11 represent/where is f.PoleID pulled from/represent?
I also provided the screen shots of the Profile variables
The string of code is being written within the pole_id field of the Riser Layer
Pole layer fields and info are being pulled from the $map feature service (see below)
The ID field marked below is the pole layer’s ID field from which I want to pull an attribute and insert into the pole_id field in the Riser layer based on the pole layer’s XYjoin field attribute matching the Riser layer’s XYjoin field attribute
Again, apologies for the repeated questions, and I appreciate if/when you’re able to provide any help & feedback.
THANK YOU!
