GPS/GNSS metadata is not populating
953
03-24-2023 07:41 AM
Laura_m_Conner
New Contributor III
All,
I am setting up a web map through field maps to collect point data. I have set up GNSS fields for :
  • Horizontal Accuracy (m)ESRIGNSS_H_RMS
  • Vertical Accuracy (m)-ESRIGNSS_V_RMS
  • Latitude-ESRIGNSS_LATITUDE-
  • Longitude-ESRIGNSS_LONGITUDE
  • Altitude-ESRIGNSS_ALTITUDE
When I am collecting data, these fields are not populating. How do I fix it? Because, bottom line, I need that data recorded.
The feature class I am collecting on/for is a hosted point feature class on ArcGIS online. These metadata fields were manually added after the feature class was created. I flowed the field names, types, and alias exactly per the GNSS metadata instructions.
The feature class has editing enabled. Yet, for some reason, the metadata fields are locked from editing. I have tried in both the feature class and the web map behind the field application to unlock them. I have yet to come across it. Is it possible or necessary to unlock these fields to populate the metadata? Also, the metadata fields are currently not visible in the popup (this might change). Is it necessary that the fields be visible in the popup?
We are using a Trimble GPS unit connected to the tablet via Bluetooth. This is not the problem. When I switched back to the table's built-in GPS, the fields still did not populate. Also, I have tried to eliminate it collecting the position mutable ways by turning off all connectivity except Bluetooth and wifi. I can not load the map without the wifi, and the Bluetooth is necessary for the GPS antenna to connect. I have been collecting the test points inside however, it says it has a connection to the GPS satellites.
In the field map application, test points are collected by pressing the + sign at the bottom right. The other attributes can be filled in, and the point submitted. The test points are not being moved, updated, or edited after the initial collection. Editing after initial collection might be necessary for actual data collection. Would this affect the metadata if it was collected?
I have exhausted all the advice available in the documentation. What should I try next? Because, bottom line, I need this data recorded.
Thanks
2 Solutions
MitchJohnson
New Contributor III
I am having the same issue
MitchJohnson
New Contributor III
I was only looking to get lat/long to populate and found that it only works in field maps if your collection crosshairs are centered directly on your location.  So you have to click the locational arrow in the top right before collecting your point.  If you move the crosshairs to a different location, it will not record lat/long.  I'm not sure, but I would imagine this is the same for the other GPS metadata.  Hope this helps.
Best,
Mitch
BHamada_GIS
Having the same issue - did you ever get this resolved?
MitchJohnson
New Contributor III
MitchJohnson
New Contributor III
Best,
Mitch
mikAMD
Occasional Contributor III
I was having the same problem. I must say this makes a whole lot of sense. Thanks!
MitchJohnson
New Contributor III
Glad it was helpful!
Mitch
