I am adding a geojson layer/file to a map in ArcGIS Online via a url. The layer is at: https://adaptergis.cityoflewisville.com/gisfiles/ParcelsDashboard.json
After adding the layer to a map, I added an additional field to my geojson file. How do I get the map to see the new field I have added?
I believe that the map saves the geojson file's schema somewhere on ArcGIS Online as an "operational layer" for my map.
Does anyone know if the schema can be updated either via the UI or the REST API?
Thank you!
