Good Morning, I am creating a dashboard that is linked to this map here. Ultimately the dashboard is working off the one-point layer that I update daily every morning. I have a buffer in miles that ranges from .5, 1, and 1.5 from the center of the purple polygon layer. My boss is wondering if there is a way to find how many points fall within just that purple boundary as well as the points that fall into each buffer. I explained that while this can be done the fact that I am doing this daily running the summaries within/select by location analysis will create a new layer and it will project wrong information within the dashboard widgets. I know that on the dashboard you can draw a circle to encompass an area and do it that way but there is no way to select that polygon (purple layer). Does anyone know away to do this?
Thank you!
