Experience Builder - Remove attribute table tab?
347
03-16-2023 09:52 AM
SFM_TravisBott
Occasional Contributor III
Guys.......how does one get rid of the attribute table tab in Experience Builder?
I removed the attribute table (it's functionality is replaced by a list widget) but I can't seem to remove this panel. Is this a setting on the map? The page?
Richard_Purkis
Hi @SFM_TravisBott
This tab is not present if you add a map widget to a blank template. May you confirm the steps you have taken to add your map.
Thanks
SFM_TravisBott
@Richard_Purkis - Yes, I started with the Foldable template because I was trying to port over something from WAB builder.
Do I need to rebuild the application from a blank template if I want that tab gone?
