don't show null values in popup
728
6
12-12-2023 07:00 AM
temprobertcottreau131313
Occasional Contributor II
I have a layer with about 50 fields that show up as 50 rows in the popup.  Most of these are Null values.
Is there a way to create an expression that will set it up to not show the fields with Null values in the popup without typing 50 expressions?
I've seen HTML solutions and ideas for Map Viewer Classic but I'm using the New Map Viewer.
Thanks to all.
Tags (3)
jcarlson
Yes! You can do this very easily with an Arcade popup element and a single expression. You can build a fields list object programmatically and check for nulls and skip them.
The simplest approach is to just iterate over every attribute in a feature:
var fieldInfos = []
var attributes = {}
for (var att in $feature) {
	if (!IsEmpty($feature[att])) {
		Push(fieldInfos, {fieldName: att})
		attributes[att] = $feature[att]
return {
    type: 'fields',
    title: 'An Expression to Skip Nulls',
    fieldInfos,
    attributes
Here it is in action, with a regular fields list to show it working:
If you have certain fields you want to skip, you can code those in, too. It sounds like there are a lot of attributes you want to catch, so I don't know if it's going to be faster to grab *everything* and then remove ones you don't want, or to manually define the list of attributes you do want. But this should get you started.
- Josh Carlson
Kendall County GIS
KenBuja
I noticed that your code doesn't show the field aliases (if they are present). Here's a modification that shows them.
var fieldInfos = []
var attributes = {}
var fields = Schema($feature).fields
    var alias = att;
    for (var i in fields){
      if (fields[i].name == att) alias = fields[i].alias
    Push(fieldInfos, {fieldName: alias})
    attributes[alias] = $feature[att]
return {
  type: 'fields',
  fieldInfos,
  attributes
jcarlson
Good addition!
- Josh Carlson
Kendall County GIS
Thanks to all.
Tags (3)
BlairMcclenathan
This is how I've accomplished this, its a little manual since you have to add the fields induvial but it loads quickly and works well for our applications (add an arcade element then add the code to that):
var fieldInfos = []
if (!IsEmpty (Trim($feature.facilityid))) {
    Push (fieldInfos, {fieldName: 'FacilityID', label: 'Facility Identifier'})
if (!IsEmpty (Trim($feature.ownedby))) {
    Push (fieldInfos, {fieldName: 'Owned By', label: 'Owned By'})
if (!IsEmpty (Trim($feature.presentstatus))) {
    Push (fieldInfos, {fieldName: 'Present Status', label: 'Present Status'})
if (!IsEmpty (Trim($feature.comment))) {
    Push (fieldInfos, {fieldName: 'Comment', label: 'Comment'})
if (!IsEmpty (Trim($feature.flowtestcomplete))) {
    Push (fieldInfos, {fieldName: 'Flow Test Complete', label: 'Flow Test Complete'})
if (!IsEmpty (Trim($feature.inspectionResult))) {
    Push (fieldInfos, {fieldName: 'Inspection Result', label: 'Inspection Result'})
if (!IsEmpty (Trim($feature.flowtestcomment))) {
    Push (fieldInfos, {fieldName: 'Flow Test Comment', label: 'Flow Test Comment'})
if (!IsEmpty (Trim($feature.flow))) {
    Push (fieldInfos, {fieldName: 'Flow Rate', label: 'Flow Rate'})
if (!IsEmpty (Trim($feature.flushingzone))) {
    Push (fieldInfos, {fieldName: 'Flushing Zone', label: 'Flushing Zone'})
if (!IsEmpty (Trim($feature.firestation))) {
    Push (fieldInfos, {fieldName: 'Fire Station District', label: 'Fire Station District'})
if (!IsEmpty (Trim($feature.lastflowtest))) {
    Push (fieldInfos, {fieldName: 'Last Flow Test', label: 'Last Flow Test'})
return {
    type: 'fields',
    fieldInfos: fieldInfos,
    attributes: {
        'FacilityID': $feature.facilityid,
        'Owned By': DomainName($feature, "ownedby"),
        'Present Status': DomainName($feature, "presentstatus"),
        'Comment': $feature.comment,
        'Flow Test Complete': DomainName($feature, "flowtestcomplete"),
        'Flow Test Comment': $feature.flowtestcomment,
        'Flow Rate': $feature.flow + ' GPM',
        'Flushing Zone': DomainName($feature, "flushingzone"),
        'Fire Station District': DomainName($feature, "firestation"),
        'Last Flow Test': (month($feature.lastflowtest) + 1) + '/' + day($feature.lastflowtest) + '/' + (Year($feature.lastflowtest)) + ' at ' + Hour($feature.lastflowtest) + ':' + Minute($feature.lastflowtest)
edward33
@BlairMcclenathan
Do you know how I would add rounding to this? I tried something like-
'Flow Rate': round($feature.flow, 2)
in the return section but that doesn't seem to do anything.
