Deleting features causes a 504 timeout error
568
11-09-2021 07:01 AM
Labels (2)
OlgaKoblet
New Contributor III
Hi all,
I am deleting features (delete_features function) from a hosted features service in chunks. It used to work with a chunk size of 500, but now I get the 504 timeout error unless I go down to the cunks of 10.
chunks = [listofoids[x:x + servicemaxitem] for x in range(0, len(listofoids), servicemaxitem)]"
for index, chunk in enumerate(chunks):
result = layer_to_update.delete_features(deletes = str(chunk).strip('[]'))
Does anybody now what happend and how to fix it?
The error message (your request has timed out):
Tags (3)
EdAmrhein1
I don't have a fix but can tell you that you're not alone.  Ever since the last AGOL upgrade I've been experiencing the same thing on code that has worked great for more than a year.  It also seems like notebooks take longer to open than they used to.
OlgaKoblet
New Contributor III
Deleting features is now (since when?) performed through edit_features function
delete_result = ports_flayer.edit_features(deletes=str(Redlands_objid))
 https://developers.arcgis.com/python/guide/editing-features/
