Changes to domain not editable in AGOL browser or in Field Maps
167
04-26-2024 01:28 PM
KentonSumpterMDA
Hi all,
When adding values to a domain, I'm finding that they're not appearing as editable when I try to edit in the AGOL Map Viewer or in Field Maps on a mobile device. The layers in question are point and polygon layers. One layer has a related table. The layers and related table were all initially made in Arc Pro, then shared to AGOL. The domain updates were done in AGOL.
RhettZufelt
MVP Frequent Contributor
When you say Not Editable?  Does that mean that the new values don't show up in a template or something else?
If just not showing in the template, you will need to add new templates for the new values.
R_
