Change text displayed in ArcGIS Online Pop-Up with Arcade
2041
01-26-2023 11:07 AM
LaurenLumHee
I created an expression with Arcade to go to a hyperlink with a 7 digit code that pulls from a field.
My question is how do I change the Text for the hyperlink?
The default is 'View', but I'd like to display that 7 digit code from my field. I added this expression into the 'Fields List' in the pop-up configurations.
Apologies if this question has been answered. I'm very new to Arcade and most posts about hyperlinking from the Text option for Pop-Up content.
jcarlson
MVP Esteemed Contributor
You'll want to add an Arcade element to your popup. This will give you the option to dynamically set HTML elements, and you can return something like this:
var id = left($feature.COA_Prop_ID, 7)
`<a href="https://www.collincad.org/propertysearch?prop_id=${id}">${id}</a>`
This will pipe in your ID to the link URL as well as the placeholder text.
- Josh Carlson
Kendall County GIS
LaurenLumHee
jcarlson
Don't put it in a field list. Your popup should let you add an Arcade element.
- Josh Carlson
Kendall County GIS
