Basemap with street/traffic direction
118
11-14-2024 10:36 AM
mikaël
Is there a basemap that exists for the map viewer that contains the street direction (one way streets), like there is on google maps?
Sorry if the info exists, I was not able to find anything.
Thanks!
Kelly_G
Try Open StreetMaps roads layer. Here is a link to one that Esri hosts : https://arcg.is/0SPPSK0
If you want to connect to the data directly try Overture maps or OpenStreetMap where oneway is a field: https://www.openstreetmap.org/
mikaël
Thanks for the suggestion.
I played with the feature layer a bit and there is an "oneway" field. But the table is so huge (53M rows), that it basically fails when I try to filter it or cut/join the data to just retain data for my work area.
Also, there are no arrow symbols on the , so I'm not sure how I would map the "oneway" field, I'd have to try if I could get it to work.
