Arcade for calculate a difference between the pixel value from DEM and a attribute from a polygon mapservice
467
10-14-2022 01:34 AM
markkellermannBWB
New Contributor II
I need some help for the follow task.
I have a DEM - imagery Layer and i have a polygon - mapservice with heights attributes.
Now i need the difference between the pixel value from dem and the height attributes from mapservice.
I want to try ist with arcade, but arcade ist not possible in the popup configuration on a imagery layer.
So I try it at the mapservice. But I dont know how I get the dem pixel value.
I can load the dem with FeatureSetByPortalItem, then I have a FeatureSet. But I need the value Pixel from the clicked coordinate.
var pt = Portal('https://xxxxxxxx')
var dgm = FeatureSetByPortalItem(pt, "123456....", ['Service Pixel Value'])
return dgm
Is it possible with Arcade?
Thanks a lot
Mark
@XanderBakker
JohannesLindner
MVP Frequent Contributor
Sadly, this is not possible with Arcade.
Have a great day!
Johannes
markkellermannBWB
New Contributor II
Pity but thank you
