arcade code to list name polygon overlap in pop up
268
10-30-2024 01:47 PM
anonymous55
Hello
I am looking for arcade code which I can list all school name in the pop up instead and user switch between them.
basically, is one building with multiple schools. I like to show name of school in pop up as list
Tags (3)
JoshuaSharp-Heward
Just clarifying as it's not super clear to me from the interface - is there a relationship class linking the building to the schools? And this is what's showing when you click on the building and expand the related schools? If not, what interface is this?
anonymous55
Hello @JoshuaSharp-Heward
no is just overlap polygon layers. no relationship class and when you click on overlap polygon layers popup in arcgis online. pop is like this which show 5 features overlap. it is just one layer.
ChristopherCounsell
MVP Regular Contributor
Check the popup title display field.
It's likely using a field like {building_type} and you can change the title to {building_name}. This will give it a better appearance in pop-up lists.
anonymous55
hey @ChristopherCounsell  Thanks for respond, I know about that. I am looking for to list everything in one pop up and don't want user to click to view list.
JoshuaSharp-Heward
I think your data will need to be slightly restructured for that. With just one layer and overlapping points I don't think there's a great way to show the information from all five simultaneously - if you had a building layer or processed the data to have a single point per location then intersecting that with the schools layer and pulling through the names would be doable.
