Hi Trevor,
Thanks for this additional info. The build date does match with 10.2 Final.
Since you mention, upgrade works with a fresh install of 10.2 Final, are there any special configuration on this portal that you see could be causing the reported behavior?
If this continues to be an issue, please open an incident with esri Tech Support so we can look into this further.
Ravi
