ArcGIS Online Questions
240
74.1M
14.7K
Open | We are increasingly being asked to create apps to track work being done by contractors doing work for the municipalit... by MelanieWawryk Occasional Contributor III 1 0 | 1 | 0 | |
Open | An organizational setting of the CDN cache control update period would be welcome.It now defaults to 30 seconds for a... by TrebinMT New Contributor II 2 0 | 2 | 0 | |
Open | I would like to see credit allocations enabled by default for ArcGIS Organizations. I believe that is an important pr... by PeterKnoop MVP Regular Contributor 1 1 | 1 | 1 | |
Open | Add an order button and functionality to feature layer lists. Currently the only way to order a feature layer's list ... by Maranta New Contributor II 1 1 | 1 | 1 | |
Open | I really like the ability to group layers in the new map viewer, and save them as a group layer. It would be really g... by StephenKing3 New Contributor III 2 0 | 2 | 0 | |
Open | Need to have the ability to select multiple features in the ArcGIS Online map viewer. Also would be helpful if you co... by AdamMoszynski New Contributor III 0 0 | 0 | 0 | |
Open | Idea: allow publishing featureserver service from a file gdb. I know editing needs an RDBMS backend and SDE. However... by Kevin_MacLeod New Contributor III 0 0 | 0 | 0 | |
Open | This would be a best improvement to ArcGIS online that ever occurred.We are looking for ways to export a folder with ... by MiralemZeljo1 Occasional Contributor 6 4 | 6 | 4 | |
Open | I need to share my data with the Group consisting of my company's peers. They will edit my data. Also, I need to shar... by AlexZhuk Occasional Contributor III 1 2 | 1 | 2 | |
Open | Hello AGOL Team, In Map Viewer it appears there is is no filter option for "within the current year". Our organizatio... by Amanda__Huber MVP Regular Contributor 6 7 | 6 | 7 | |
Open | Arcade expressions currently are not supported for Heat Maps.To use Arcade expression with the Heat Map symbology sty... by JasonXiao New Contributor II 0 1 | 0 | 1 | |
Open | Can the option to add transparency to labels be added, please. I often need to display boundary names on polygons an... by KKelechenyi New Contributor III 2 0 | 2 | 0 | |
Open | 1 | 0 | ||
Open | Instead of manually assigning the group category to the layer via the ellipsis within the list view in the group.It w... by AndrewHankinson New Contributor III 2 0 | 2 | 0 | |
Open | In ArcGIS Online, you can create a new Feature Layer via Content --> New item --> Feature layer. Currently that workf... by PeterKnoop MVP Regular Contributor 0 0 | 0 | 0 |
Idea Submission Guidelines
User | Count |
11 | |
8 | |
6 | |
6 | |
6 |
