Recently I was asked to help create an email link in a pop-up to send information about related records. Building on the example about retrieving the maintenance history posted here, Let's add a button that will send an email with that history.
A mailto link may contain a couple of elements:
- the email or emails to send the mail to
- optionally the CC and/or BCC
- a subject
- and a body
The HTML we will use for the button is rather simple. It consists of an anchor with the mailto link (espression/expr1) and inside that anchor the button (see lines 5 to 7):
<b>Maintenance history:</b><br />
{expression/expr0}
<br /><br />
<b>Email History:</b> <br />
<a href="{expression/expr1}">
<img alt="Email" height="50" src="http://icons.iconarchive.com/icons/iynque/ios7-style/1024/Mail-icon.png" width="50" />
</a>
The pop-up looks like this when the user clicks on a point (sorry for mixing Spanish and English):
When the user clicks on the button this will create an email if you have an email application setup on your machine:
Let's dive into how to create the Arcade expression to get the information and structure it in such a way that it creates this email. The part of connecting to a related table and filter the table based on the ID of the hydrant has already been explained here: (Using FeatureSetBy functions in Arcade to drill-down to other layers and tables) so I won't go into detail. I used the same GetHistory function, with a small but important change on line 13:
Function GetHistory(hydrant_id) {
var tbl = FeatureSetByName($map, "Maintenance");
Console(tbl);
var sql = "COD_HIDRANTE = '" + hydrant_id + "'";
Console(sql);
var tbl_filtered = Filter(tbl, sql);
Console(Count(tbl_filtered));
if (Count(tbl_filtered)> 0) {
var history = "Please find below the maintenance history for Hydrant " + hydrant_id + ":";
for (var maintenance in tbl_filtered) {
var txt_date = Text(maintenance.Fecha_Mantenimiento, ' - (Y/MM/DD) ');
var txt_man = txt_date + maintenance.Mantenimiento;
history += "TextFormatting.NewLine" + txt_man;
} else {
var history = "No history for Hydrant " + hydrant_id;
return history;
I am adding "TextFormatting.NewLine" as string and not as constant. In fact this string could have any unique content, but I chose to do it this way. So the resulting string contains all the history on a single line and the text "TextFormatting.NewLine" will be used later on to replace it by something that can be used in an URL as will work as new line in the mail ("%0D%0A").
The other part of the expression is used to call this function and define the other parts of the email:
var hydrant_id = $feature["COD_HIDRANTE"];
var email = "someone@someplace.com";
var cc = "other_one@someplace.com;other_two@someplace.com";
var bcc = "secret_person@someplace.com";
var subject = "Maintenance history of Hydrant " + hydrant_id;
var body = GetHistory(hydrant_id);
var params = {cc: cc,
bcc: bcc,
subject: subject,
body: body};
var url = "mailto:" + email + "?" + UrlEncode(params);
url = Replace(url, "TextFormatting.NewLine", "%0D%0A");
return url;
Let's explain what we do in this second part of the Arcade expression:
- We read out the ID of the hydrant on line 1
- Define the emails to send the email to (including 2 CC's and 1 BCC) on lines 2 to 4.
- The subject is basically a text including the variable hydrant ID
- The body is generated using the function GetHistory explained above
- On lines 7 to 10 we create a dictionary called params with the properties cc, bcc, subject and body and we assign the values from the variables cc, bcc, subject and body defined on lines 3 to 6
- On line 12 we use the new Arcade function UrlEncode (released in version 1.7) that will encode the URL parameters correctly
- On line 13 we replace the text "TextFormatting.NewLine" by a text "%0D%0A" which will create the new lines where needed in the body of the email. If we would have done this before using the UrlEncode, this would have converted the text to "%250D%250A" and probably caused the new line not to work.
If you have any questions, please use the "Add a Reply" button to let me know.
Final code used is listed below:
Console(tbl);
Console(sql);
} else {
return history;
bcc: bcc,
subject: subject,
body: body};
return url;
