Analysis from ESRI Developer Summit 2024
589
6
03-15-2024 07:22 AM
LanceKirby2
Occasional Contributor II
At the dev summit a sample analysis was shown around the 35 minute mark. @AndrewSakowicz you mentioned sharing the queries used to build that analysis but I didn't see any follow up on that. It would be great to have access to those. If they're available could you point the way?
AndrewSakowicz
@LanceKirby2  Thank you for attending our session.  As mentioned, we are working an analysis import feature (Q3 2024).  In the meantime, we’ll write a blog, including a script how to import.
But if don’t want to wait and are willing to follow these “unsupported” steps, here is how:
  1. Ensure you are on 2023.3 release
  2. Back up PostgreSQL database (or at the minimum Analysis table)
  3. Create new collection named "Prod". If you want to use it for a different collection name, you’d need to globally replace “Prod” text to match your collection name.
  4. Create new analysis with any name (that matches your collection name, e.g. “Prod”.  )
  5. Edit Analysis table as follows
    1. View/Edid Data using PG Admin
    1. Navigate to your analysis name row, e.g. “Prod”
    2. Replace the content of the configuration cell with the attached json file
    3. Save
AndrewSakowicz
    3. Save
LanceKirby2
Thank you!
TarigAhmedTXHSDS
Thank you for sharing :). I'm looking forward to seeing the blog.
Could you please post screenshots of the final analysis?
AndrewSakowicz
Please see below.
TarigAhmedTXHSDS
Thank you so much for quick response 🙂
TarigAhmedTXHSDS
Question: We have a High Availability GIS System in AWS. What is the downtime mean in the screenshot below? is it the load balancer?
