Under Consideration | One of our most anticipated usecases is to display geolocated Images / Videos on the 2D map. We tried RasterLayer, KM... by VolkerReinhard Emerging Contributor 0 2 | 0 | 2 | |
Under Consideration | Real-world Problem - In Urban Search and Rescue, every second counts. When there is a sudden building collapse, firef... by pjdohertygis Regular Contributor 2 3 | 2 | 3 | |
Under Consideration | ArcGIS Javascript has this MediaLayer API (https://developers.arcgis.com/javascript/latest/api-reference/esri-layers-... by Kia_BeeNg Emerging Contributor 1 2 | 1 | 2 | |
Under Consideration | Currently the deprecation item flag is mostly useless. It can be a deterrent from new users picking a service but the... by stevegourley Frequent Contributor 9 2 | 9 | 2 | |
Under Consideration | Since more modern cars are coming with CarPlay and Android Auto support, I think it would be great to be able to get ... by JohnMDye Frequent Contributor 8 2 | 8 | 2 | |
Under Consideration | Hello,We talked about this at the Developer's Summit, and it sounded like this was a possibility, but I wanted to pos... by MichaelHamsa Regular Contributor 3 1 | 3 | 1 | |
Under Consideration | There are several mobile app solutions on top of the ArcGIS Runtime, but none of them are designed for the ArcGIS Jav... by AlpineTech Regular Contributor 10 1 | 10 | 1 | |
Under Consideration | I've been programming with ESRI's frameworks and SDKs for some time now and they seem quite powerful to me. However, ... by JuhoVainio Deactivated User 10 0 | 10 | 0 | |
Under Consideration | Hi, I'm using an embedded platform that uses a Freescale i.MX6 dual core ARM Cortex A9 processor. I would like to... by ElvisDowson Emerging Contributor 4 0 | 4 | 0 | |
Under Consideration | Most of the time i work with either ArcGIS API for FLex or Javascript. Its part of my work to create graphics layer f... by ZahidChaudhry Deactivated User 27 1 | 27 | 1 | |
Under Consideration | I think that Esri should make a class that support to consume Web Coverage Services (WCS). Like WMSLayer class. by JesúsVillajos1 Occasional Contributor 7 0 | 7 | 0 |
Idea Submission Guidelines
