Hi guys,
Comming from this question I'd like to suggest the same feature which is already available in ArcGIS Pro.
In my use-case I get Wgs84 coordinates from an external source which could be anywhere in the world.
Similar to GetTransformation I would like a method which gives me the best fitting local/smallest "Projected Coordinate System" (PCS) SpatialReference (wkid, EPSG Nr) for a given area/envelope/array-of-points.
thanks
Soko
