I was wondering if it was possible to use multiple ArcGIS Camera at the same time. The issue I'm encountering is terrain LOD flickering as well as uneven LOD on one camera (as in the attached screen shot).
The setup is the following. One camera is in the gimbal and it's forward vector is represented with the green line. So in the picture it is looking in front of the UAV. The second camera is attach to a spring arm.
As we can see, from the perceptive of the second camera the terrain on the left is not at the appropriate LOD.
