Unity Maps SDK Questions
98
1.1M
297
POST | Hello,Mostly directed towards the ESRI team here but just curious if there is timeline for if and when we can expect ... by sebastianbrauer Emerging Contributor 0 0 | 0 | 0 | 44 | |
POST | Hi everyone,I am currently working on a project where I successfully load LiDAR data into the frontend using ArcGIS S... by AbhayBhorayat New Contributor 0 0 | 0 | 0 | 85 | |
POST | Quick one. Does ArcGIS SDK for Unreal support Path Tracer rendering?From my very limited experience and testing, it a... by MatthewWalker10 Occasional Contributor 0 0 | 0 | 0 | 100 | |
POST | Hello, I'm using ArcGIS for Unreal Engine and I have noticed that the normal buffer is basically empty for the terrai... by dacresmu New Contributor 0 0 | 0 | 0 | 115 | |
POST | Engine version: 5.5.1Plugin version: 1.7.0Heya,Been trying to make building attribute filter for a building scene la... by Ayhan_Exe-Interactive New Contributor 0 0 | 0 | 0 | 132 | |
POST | Second post in quick succession unrelated to the first. I have been trying to develop through construction blueprints... by sebastianbrauer Emerging Contributor 0 2 | 0 | 2 | 166 | |
POST | Hey first time posting to this forum but over the last few weeks I've been running into this issue where the basemap ... by sebastianbrauer Emerging Contributor 0 1 | 0 | 1 | 149 | |
POST | As the following picture said, if we use the WGS84 in local scene, data will be converted to Plate Carrée (WKID: 3266... by jiaqili1 Emerging Contributor 0 0 | 0 | 0 | 155 | |
POST | Hi there,I'm working with Unreal Engine 5.5.1 and the ArcGIS SDK 1.7 on behalf of a client. I've been following this ... by dborrelliAU ![]() 0 1 | 0 | 1 | 206 | |
POST | Hi everyone,I'm working on a project in Unreal Engine where I need to integrate large-scale geographic data using VTP... by jiaqili1 Emerging Contributor 0 1 | 0 | 1 | 219 | |
POST | Hello everyone!I think the Unreal Engine SDK has bugs with authentication for private layers. I followed all the setu... by PhucTran1 Occasional Contributor 0 2 | 0 | 2 | 297 | |
POST | While working with ArcGIS maps in Unreal Engine, an issue with scaling in Local Mode (flat map display) was identifie... by DimidDidenko New Contributor 0 0 | 0 | 0 | 186 | |
POST | Hello,I am trying to get the SanFrancisco_Bldgs Arc GIS3DObject Scene Layer and TotPopTile2 Arc GISImage Layer with P... by Games4SciAndEng New Contributor 0 1 | 0 | 1 | 213 | |
POST | Hi,I'm using ArcGIS for Unreal 1.7 in UE5.3, global maps with origins at the planet surface.I know it is no longer st... by salvaba New Contributor 0 0 | 0 | 0 | 230 | |
POST | Trying to add the OpenStreetMap 3D buildings as a layer to my map in Unreal 5.3, but it doesn't seem to be working. M... by CarterAtClay New Contributor 0 1 | 0 | 1 | 256 |
