Human Geography Basemap for Enterprise Portal
461
08-03-2022 01:44 PM
RyanBohan
Occasional Contributor III
Please update the Human Geography Basemap to be Public for use in Portal.  I am able to add it through the Living Atlas in Portal.  However I am unable to share the map with the Public.
Thank you
BernSzukalski
Esri Frequent Contributor
That basemap can be publicly shared from Enterprise. Try opening this test map using the Human Geography basemap I just authored in one of my enterprise portals:
Human Geography Test (arcgis.com)
Can you share other maps publicly?
RyanBohan
Oh thanks, I will try that, I figured I would be unable to update Sharing Status, as I do not own them
BernSzukalski
It's public, so no ownership is required to change the sharing status. One thing you might need to consider is whether or not your organization administrator has enabled you to share content publicly. If you can share content publicly, then you can use this basemap. Send me a link to test if you like - bszukalski@esri.com
