@BarbaraSj After looking at the data I am puzzled by your workflow. I think you are going wrong here:
I enable locations for Fueling points (A). I then create a relationship between the two data sets where fueling point ID( is unique on dataset fueling point (A)).
What was the field from the customer data used in the join?
From the relationship created, I then enable location for 2 columns:1st time fuel point ID and Last time fuel point ID. When trying to create link maps i get the error the layer used to enable location or create relationship contained multiple features with identical names try using a layer with unique identifiers
The customer data doesn't contain latitudes and longitudes for the First and Last Fuel IDs, for you to enable location so I am not sure how this was done.
I was able to achieve results with the following workflow
- Enable Location by LAT & LONG on Fuel Point ID (Sheet2.Table1 in give n dataset)\
- On Customer Data.Table1 Enable location -->? Geography twice usingFirst and las fuel Point ID
- Use both the Geographies to create a Link map
I am hoping this is what you need. If not, I recommend you prepare Lat/Long fields for First and Last Fueling points instead of IDs in the Customer dataset, then enable location XY on both.
Akshay Harshe
