Bar Chart with date on the x axis
389
11-02-2023 04:24 PM
Status: Open
mklatt_cityofventura_ca_gov
New Contributor III
It would be create create a bar chart using a date field.
This would be for a chart that has an x axis for dates with a reporting period like by day, week, month, or year.  Thinking something similar to what ArcGIS dashboards can do.
3 Comments
AkshayHarshe
@mklatt_cityofventura_ca_gov Thanks for posting the idea. We will consider this.
However, this should be possible to use the data components that are calculated by insights and using a cross filter on 2 or more charts.
ChrisWesson
Note that the cross filter Akshay mentions allows you to take the functionality further.
For like-for-like functionality with what you mention from Dashboards all you need do is select a date-time component such as Month from the data pane, and drag that to a bar or column chart.
Thank you! the idea would be to have mulitple years on the same chart visualized by year/month.
Currently I use a calculated field and that gets the job done, but is not ideal.
