Accuracy analyis in deep learning project
624
07-26-2020 02:00 PM
RitikaPrasai1
I am working on a deep learning project and trying to label data to provide as training samples. I have already tried by increasing, decreasing the polygon size, number and exported those using deep learning algorithms in ArcGIS Pro.However, when I train my model using those exported samples- I always receive the accuracy as 'nan' . Could someone suggest me what is the cause. I have attached screenshot here. Thank you!
DanPatterson
There are many links trying to explain nan on the web.
A web search using .... deep learning accuracy nan
yields many examples, for instance....
python - Deep-Learning Nan loss reasons - Stack Overflow
It is hard to figure out exactly your workflow from just the image.  Perhaps you can provide a textual description as well
... sort of retired...
RitikaPrasai1
Thank you!
